1 - 3 of 3 Posts
Does anyone know if the V6 (non-heated seat) models are pre-wired for heated seats? Basically did the factory use the same wiring harness on all models?
I wanted to pick up some leather heated seats and the controls to go with it.
My thought, is that they use a different wire loom. You could look under leading edge of each of the seats, to see if there is a 12 pin rectangle connector stowed in that area (that is the location where the seat heat modules would be located). An, at he center console you would need to find two 8 pin rectangle connectors stowed, that would be used for the module containing the T/C an seat seat function buttons. If no joy, I doubt that the wires coming from the power sources are installed either. I did see a past thread, where a member added an aftermarket seat heat kit in his car. It included pictures along with the info on the installation. It may be what you would have to do (leather seats or not).
1 - 3 of 3 Posts
