Is it a must with a 3600 stall? I tend to think so but I was just wonderring what you all who have high stalls have done?
Yes you need one, I went with Lashways with the deep pan. But Greg is stand up and you cant go wrong there.absolutely... might as well do a deep pan while you're in there too, and the wide mouth filter... Chris over at Pace sells a kit![]()
He's probably spinning all over the place. Needs some DRs.Thats what I thought. My buddy just got a lot of work done at a local shop and they installed a aftermarket stall and no cooler. I thought that was a little strange. My mistake he has a 3200..
He went [email protected] with a 2.05 60' last year with a catback, vararam, and tune.
After install of 1 7/8 headers, full exhaust, 3200 stall and retune he went [email protected] with a 2.0 60'.
Not sure the rules here I got :slap: recently... but here is a link if it is O.K. to a good kit with a few nice options!Links to said kits?
Perhaps the retune was not good?, a tuned verter should give you .3-.5 sec less in the 1/4, easy.
Well, the stall won't make the car spin down the track. Just mainly on the launch. And once the tires actually catch, the car will get up and go. So something is up. Could be the tune.From watching the car at the track he 60'd better then before and the car was not all over the place. If his 60's were higher or if the car was spinning down the track I could understand.
Like I said. Sounds like driver/tire problems more than anything.
+1Like I said. Sounds like driver/tire problems more than anything.
So if I cut a 2.08 60' and ran a [email protected] before Headers,full exhaust and stall then get those mods and a tune and go back to the track and cut a 2.02 60' and run a [email protected] thats normal? I would have to cut a sub 2.0 to run the times that I ran in my car before those mods is what your saying? If thats the case then whats the point of doing those mods?+1
If its not cutting sub 2.0 60' after the 3200 Stall then someone doesn't know how to launch it or the tires are not hooking. One of the two...
