Does anyone on the forum know of anyone with an LS9 crate engine in their G8?
Not to me, I would just build a really bad ass LS3 for a 1/4th of the cost. But if you can drop 35k on a motor like that, it's probably chump change to them.Would it be worth it for the cost? I can think of alternative routes to get the same horsepower at half the price point.
How would you build an LS3 stronger than a LS9?Never heard of anyone doing it. Don't know why anyone would either considering you could build an even stronger LS3 for 1/3 the price.
With better parts than the ones GM picked out.How would you build an LS3 stronger than a LS9?
Both are basically the same engine, 6.2L small block, but the LS9 is supercharged from factory. New headers, cam, stall, maggie, and a tune would probably be more powerful than a stock LS9 and would probably cost 10k less than a crate LS9, which is 21k.How would you build an LS3 stronger than a LS9?
I was thinking about the LS9's durability features, like oil jets to cool the pistons, thicker head bolts, and stronger block and heads. The block and heads are the same design as LS3/L92, but use the "roto-cast" method to make the aluminum more dense. The LS9 block also uses billet steel main caps instead of cast iron.Both are basically the same engine, 6.2L small block, but the LS9 is supercharged from factory. New headers, cam, stall, maggie, and a tune would probably be more powerful than a stock LS9 and would probably cost 10k less than a crate LS9, which is 21k.
