Engine/manifold vacuum is the difference in pressure between Intake manifold pressure and static map (atmosphere pressure). if map kpa at 60mph is say 55kpa, and assuming static map is 100kpa (you can observe map kpa with engine off, and that would be atmosphere pressure or static map), then you can say vacuum would be 100-55= 45kpa.
Then to play with DOD you can check this thread, i talk about the needed details
http://www.g8board.com/forums/showthread.php?t=28312&highlight=dod+tuning
mainly, to keep it longer with stock cam, you'll decrease the numbers in the DOD enable/disable vacuum tables, why ?
Look at the description on the enable/disable vacuum tables,
enable: Engine vacuum level must be above this to allow switch from v8 to v4 mode
disable: If in v4 mode, vacuum level below this would force a return to v8
get the scanner and see what the map is doing in say 6th gear at 50-70mph, then decrease the enable rpm values accordingly. most do it 5 decrements, and about 2-3 decrements for the disable table. i know i used to say tps% had in impact in dod, but futher testing showed me enable/disable vacuum and timing were more important to change than tps%, but as always, test, test and keep testing until satisfied :thumbsup:
Have fun.
