1 - 8 of 8 Posts
Can anyone help me out ? I changed my brakes and rotors and even bleedid the brakes on my G8. The car stops perfectly fine and has brake fluid but the brake light stays on
That light can illuminate 3 ways. #1--- Parking brake switch faulty (doubtful). #2---- EBD source (Electronic Brake Distribution). You would *not want* that to be the problem. #3--- Your master brake cylinder has an internal *low level* sensor in the fluid reservoir. It could be faulty, or hopefully you need to add more brake fluid to it. That may correct that sensor from seeing or sensing a low fluid level in that reservoir (even if it doesn't appear to be low).
1 - 8 of 8 Posts
