101 - 120 of 133 Posts
hasa Member
There is a new LED bulb on the market from V-LED's called V3 Triton.
The Triton looks like it would work in the rear but wouldn't in the front for the same reason that the LED Decoder wouldn't work in the front. See TurboMike's post above.
anyone use the Triton LEDs on rear yet? I definitely need something brighter than stock but $99 seems a bit steep...lifetime warranty is nice though hmmmm.
Update on the sunroof lights. Its 3 194 bulbs-> 2 side spotlights and 1 bulb in the middle that looks like four from inside the car when its on. All 194. Just changed the center one to a red 194. That's what lights when a door opens.
I have the Spyder LED Audi type headlights. I am looking for the proper swap for my front turn signals which are P21's. Does anyone know the LED 360 bulb I would need for that? Notice the off center tabs.
I kno this is an old thread but any pictures on resister placement? Going to do this next weekend
Sleeper, what bulbs and colors did you do? Mine are done except for turn signals. I have the Spyder LED lights and thought those bulbs were 1157, but they were this P21w (7507) bulb. Just have to do resistors myself and were done.
Ya I have done the V3 Triton upgrade in my car. I have the the V3 switchbacks, rear turn signals, and reverse lights
It was a really easy install if you actually take the headlight assembly out. All I did was took the biggest spacer, put it on the bulb and then in the head light assemble
Then i used outdoor silicone to keep it waterproof
To connect it to the headlight, i just vampire clipped with electric grease to the stock wiring.
I Tried to PM 5litrarag.. anyone know if he is still around??
Has anyone installed the V3 Triton Switchbacks into the front turn signals? When I emailed the company, they said these will not fit our car.....is that true?
I have installed them in my car, but the company is correct they are not a direct fit.
You guys are crazy for paying for SuperBrightLEDs ridiculous prices! There are brighter, and far cheaper bulbs on ebay.
I got a 10m roll of RGB5050 SMD LED lights with 300 LEDs, 3M sticky back, with an IR remote and INFINITE color options on my remote for $20. SuperBrightLEDs wanted $130 for the EXACT same freaking thing. All their products are of similar pricing structure.
Have Bar Will Travel
guys that replaced the brake/tail lights
I've bought 2 different 7443 tower bulbs, both with different numbers of LED's but due to placement and the houseing I thought I should get something with lights around the tower and then a set on the end.
neither bulb I've bought - both from amazon - will actually fit in the whole. they are all about an 1/8 inch too big in O.D to fit into the socket. the lights work well, plug fits etc - but trying to get into the socket is a complete no go.
I'm not modding the light fixture - when any incandescent 7443 fits perfectly fine. (PS yes I did try to grind on one of them to make it work - took way too much and damaged the LED lamp to where it had no structural integrity)
anyone have this problem?
CAN Bus Back-up Lights?
On a non-sponsor's web site, they list several alternative 1156's for replacement backup lights. One of them is a CAN Bus LED bulb. They say,...
...bulbs are specifically designed with supervision circuit to allow them to be used with CAN(Controller Area Network) Bus equipped vehicles without triggering the OBC (on-board computer)...
Does this benefit our cars? I was not aware that we had a warning system on our lights.
I'm looking to replace my license plate lights, as well as my rear brake lights.
These 7443 lights from VLED look nice but are pricey at $50.00 vs. $5-10 on ebay/amazon
http://www.vleds.com/7443-21-red.html
Is there a better option out there? what are the risks of causing damage to your electrical system with certain aftermarket lights?
And if I put LED lights on my license plate - does that mean I have to replace all 194 lights in the car as well?
Thanks!
EDIT: I ended up just getting normal 7443's and 194's for only $10 vs. $50-70 for the vleds. Apparently red brake lights - as listed in the first post - aren't DOT approved in Canada. Both lights were made by sylvania..the 194's aren't as bright as the original lights, more yellow too. The store was recommending something like a 285 (which is probably wrong). Oh well.
There was also a house fire in town today which was caused by a highly modified pickup truck. Pics on tv showed that the back of the truck on fire. So I went with the normal lights partially to avoid something like that as well...and my v6 g8 only has michelin pilot sport a/s3's and a normal k&n air filter...which is good enough
