Z/28 it will be rarer than a base C7I'm curious as to which will be faster, both straight line and road course...
Which would you rather have as your weekend hell raiser?
Rarity will go to z/28 for sure
That's an option. You can get it w/AC.It will probably be a very close race between those two no matter what. As far as which one to pick I'd have to go with the C7 hands down. The Z28 being stripped down the way it is really requires a specific buyer. No AC is no bueno.
Really? Has some independent rag posted the test results?The C7 takes it in every catagory at the track.
Yeah after I posted that I though it might be. I knew it had no radio and no AC on the base model and I knew you could get at least one of those things as an option. Is a radio an option?That's an option. You can get it w/AC.
Radio only gets 1 speaker, just for the door chime. That could be easily fixed.Yeah after I posted that I though it might be. I knew it had no radio and no AC on the base model and I knew you could get at least one of those things as an option. Is a radio an option?
The Vette weighs 3298, which is more than the base C6 but less than the Grand Sport by about 50lbs. Most of the weight went to beefier half shafts, brakes, seats, direct injection and infotainment so it's good weight.Corvette around 3000 lb. 450 hp. its a car that can only get better every yr. forward .
Z/28 is the third round of this car which still starts out with v6 .Point being one is built for everyone ,one is for running 911's
