1 - 5 of 5 Posts
I'm replacing my rotors and pads and wanted to replace the caliper pins and bolts as well. Do you guys have the part numbers for the pin and calipers for the GT Front and Rear Calipers??
Thanks in advance
i dont have the parts, but you dont need to replace these parts. just loctite them on reinstall.
Its Good To Be Tha King
Are they TTY bolts? If so, I'd reuse them once, but I'd replace after 2 uses. Bolts are cheap, and it's always better to be safe than broke down on the side of the road, or even worse.
Greg at Pace Performance can get you everything you need.
i've read varying opinions on the site. Generally what I hear is that people see the front bolts that have a torque spec then 120* after that and usually this applies to TTY bolts. However the rears just give you a torque setting and a few reputable people have stepped in and said there's nothing in the manual about needing new bolts and that people shouldn't assume you need new hardware based on the torque specs.
Myself and many have resued them without an issue, if there was an issue you'd see several long threads about it. However, others are cautious and for just a little money bought new bolts. I'd say as long as you loctite them with the color they had from the factory you should be fine. My pins were blue and caliper mounting bolts were red.
1 - 5 of 5 Posts
