Should look really good. You're going to have to roll your rear 1/4's or the tires will rub (even stock height tires.) Also, I bet you really notice the weight difference of those wheels on a v6 car. They made my car feel a little sluggish when I had them. I think they carved them out of solid blocks of lead.
While the V6 does not match up to the GXP or GT horsepower wise, that does not change the passion owners have for their G8's.
Why not start our own registry as well, following much of the same layout.
My info:
Year: 2009
Colour: Panther Black Metallic
Options: Sunroof, Comfort and Sound...
Hello everyone! I have recently changed out my 3.6l engine for another used 3.6l. I have tested the battery, checked all the electrical connections. The starter tested good and the starter relay is good. The issue that I am having is it has a very weak crank if I'm lucky maybe one rotation and...
I currently have a v6 G8 that I'm trying to swap into a 5.3l. Is there any major differences between the v8 and v6 g8s that could make this swap more difficult ?
So last weekend I just had my overkill tune installed (thanks to a vary big help!!) and thought I would write a little review.
Right off the bat you can feel the throttle is more responsive the faster you push the more it goes. But at the same time it isn't enough sensitivity to hurt anything...
Hey fellas first time posting on here but I’m having some issues with my G8 in which the key is stuck in the ignition. Figured this could be the place to help figure it out before I take her into a dealer/shop.
Just bought the car a month ago and not entirely familiar with it yet.
Then being...
