1 - 5 of 5 Posts
1) cam motion ls2 stage2 no need for stall ( LS2 Stage 2 - CAM MOTION ) all specs on website
2) rpm outlet stage 3 it needs stall ( https://www.rpmoutlet.com/08-09-pontiac-g8-comp-cams.htm ) it is the last one on the website
3) other
i am looking for max performance the car is kinda daily driving i am only looking to install cai, headders, catback, and camshaft, maybe intake manifold. i have 2009 g8 gt auto trans
Not sure if you noticed it or not but those RPM Outlet cams are DoD cams. The Cam Motion cams are appropriate if you are deleting the DoD.
I would delete the DoD and go with the LS3 Stage 2 cam not the LS2 version. The G8 GT has essentially LS3 heads and intake so the LS3 version of the Stage 2 cam is appropriate.
Naturally as-pirated
XFI AFM cams are very interesting. Never heard from anyone who has installed but looks good.
I like XFI AFM 270, no need for stall with Comp 270PHR15 which is 220° int and 115 LSA.
Also consider higher ratio rockers, is what all who have large base circle AFM use. Also consider 4° advance in a custom grind.
Here's a deal off the shelf:
https://www.amazon.com/COMP-Cams-656-422-13-Camshaft-270PHR15/dp/B0066STV9Q includes cam, lifters, lube and instructions for $453.
1 - 5 of 5 Posts
