1 - 15 of 15 Posts
Is there a new center speaker option? I did a search and the one that people have used in the past has been discontinued. I'm looking for a plug and play speaker, much like the Polk's I bought for the doors...not looking to cut or drill anything.
Thanks guys!
Official Top Gear Addict
Not sure about the depth, but I was going to try a Pioneer 3.5 to match brands with my door speakers. Maybe someone in the know can chime in. Subscribing.
Mack
Sub'd
Just unplug it. I upgraded it and subsequently removed and sold it. It's simply not needed once you upgrade the rest of the speakers.
Texas state of mind...
Yup. It actually hurts the stereo separation. I said goodbye to all the dash speakers a while ago.
OGOC Member
Do any of you guys that have disconnected/removed the middle dash speaker use OnStar and/or Bluetooth via the CoStar product (which uses the OnStar audio)? If so, does OnStar/CoStar still work well?
Bump so someone can answer SublimeGT's question
maybe someone and you can split the cost and buy the pair one for each...
Throw in a resistor, really easy and cheap fix. I still have my OnStar enabled, i dont really "use" it but it still works. By adding that $2 resistor all your doing is essentially stepping down the volume so its not blaring loud.
I would recommend this route over spending money on any aftermarket speaker.
Discussion Starter #12
I unplugged mine a couple of days ago. Huge improvement! I won't be replacing it, just gunna leave it unplugged. Thanks!
Yup, I was resistant to do that at first, I even had a 16 ohm driver in there. It's STILL better to turn it OFF, it does nothing but ruin the stereo image. And in a car with true signal processing, it's worthless.
OGOC Member
1 - 15 of 15 Posts
