Awesome thanks for the advice probably going to be doing this were did you get your studs fromI just changed my rear studs last weekend. I was putting on my rear Brembos. The studs will come out if you drill a access hole in the backing plate in between the caliper mouting holes. I used a 3/4 inch hole saw bit. Its tight but can be done. I used longer studs and 15mm spacers to clear rear Brembos with stock 19's. Front studs are easy as changing your brakes.
