Check engine light after muffler off
So I bough my g8 GT with after market exhaust on it... it is still catted due to emissions laws in Washington where I bought it from, here in Montana we have no such thing so I took the mufflers off to give it a little bit more loudness and rumble because I miss my subarus boxer rumble and a day later I had a check engine light come on. I used a diongnostics scanner and it came up with "System running too lean" and the definition of the code is FUEL TRIM SYSTEM LEAN BANK 1. Something to do with the fuel pump, fuel pump control module or the fuel pump driver module but as soon as I put the mufflers back on to see if that's whats wrong the check engine light went away... I don't understand this... I know in my Subaru when I put cattless headers, up pipe, down pipe and cattless cat back the check engine light came on due to the ecu detecting a difference in the exhaust by the O2 sensors. Did the check engine light come on due to no mufflers or is it really a fuel pump problem?
