Yeah, I know it sounds pretty basic, but even if you think you "eyeballed" things close enough, it probably isn't.
Case in point: A couple of weeks ago, I installed new BMR toe rods on the rear of my G8 GT. Before taking anything apart, I marked the offset washer and frame at the inner bolt, so I could reassemble it back the way it was. Well, that wasn't even close. After getting everything back together, I drove the car around the neighborhood to settle the suspension, then pulled it back in the garage. Just walking around the car, the rear wheels looked OK, but they did seem to be toed in just a little.
Curious, I set up a jig to measure the toe using 2 steel rulers against the outside sidewalls, quart paint cans to hold them up at the same height, and 2 measuring tapes running under the car from the outside edge of each ruler, one in front of the tread, one in back.
It was over 1/2" off. :embarrassed:
I double checked to see if the measuring tapes were hitting anything under the car, even swapped them front to back - still the same measurement. So, I crawled back underneath and loosened the nut on the inner bolts, then turned them just a few degrees so that the paint marks I had made (before starting) on the offset washer and frame no longer quite lined up, and measured the toe again. 1/8", much better - at least good enough to drive it a few miles to the alignment shop.
Specs from the alignment shop:
(* is out of range)
Before: Rear camber left -1.1 Rear camber right -.05
Rear toe left 0.28* Rear toe right 0.13
Cross camber -.06
Total toe .41
Thrust angle 0.08
After alignment: Rear camber left -1.0 Rear camber right -.05
Rear toe left 0.19 Rear toe right 0.20
Cross camber -.05
Total toe 0.39
Thrust angle -0.01
So, I was able to get pretty close just using some measuring tapes to check the toe, but still not within specs - at least it wasn't over 1/2".
(* is out of range)
Cross camber -.06
Total toe .41
Thrust angle 0.08
Cross camber -.05
Total toe 0.39
Thrust angle -0.01
