I posted this under the engine section but it might be better suited here,
Ok so I have done some searching but didn’t find any answers. My car every once in a while turns the stabilitrak off and you can’t turn it back on until you turn the car off and restart and it might not do it again for a week or two. Now the car has started activating the stability assistance when going around a curve to the right and it scares the crap out of me, has done it at slow speeds and high speeds. First time it happened I thought maybe I hit a piece of gravel or something and maybe a tire spun a little but that apparently isn’t the case. Anyway I don’t have any check engine lights or anything but I finally put a scanner on it the other day and pulled the C0186 code which is Lateral Accelerometer sensor malfunction. So has anybody replaced the sensor or should I be looing at something else?
