1 - 4 of 4 Posts
Red LCD DIC split screen started having this problem on my 2009 with 28,000 miles. Ive read the previous posts on this subject however none of them give a final outcome or resolution for the repair. Battery was changed last year and no other issues are present. All help will be appreciated Thanks
Exactly how is the screen malfunctioning i.e. garbled text, blank, dim, etc.? Probably irrelevant, but what brand of battery are you using? Have you checked the battery post connections and the battery ground bolt? https://www.g8board.com/threads/battery-ground-bolt-read-and-check-yours.224746/ In the past, it has caused a variety of issues for quite a few forum members even though you stated no others issues are present.
Failed to mention it may be beneficial to contact Chris at White Automotive and Media Services if nothing pans out here on the forum. Good luck
The top third of the screen will show the upper part of vehicle speed , when showing odometer it reads complete in the upper part of the screen but at the bottom it duplicates it. when in engineering mode only shows 3 top lines. I will check the ground bolt but the car has never been driven in the winter and rarely in the rain. Thanks for the thoughts. Bill
1 - 4 of 4 Posts
