1 - 20 of 60 Posts
Supporting Vendors
RGBW™ LED Demon Eyes
The only LED Demon Eyes made in USA!
Diode Dynamics is pleased to announce RGBW LED Demon Eyes, designed for use with Mini H1 projectors, or OEM Pontiac G8 Projector applications through custom mounting. Demon Eyes are small, high-power LEDs that illuminate the projector lens inside your G8's headlight projector, for a unique, custom look. Our demon eyes are made in USA, and feature bright, full multicolor control!
Specifications and Features:
- RGBW LEDs, for full multicolor and true white illumination
- Fully waterproof and shockproof constant-current drivers
- Compatible with any standard RGB or RGBW controller
- Brackets included for Mini H1, or custom-mount anywhere you wish
- Small size for easy custom installations
- Designed, tested and manufactured in the USA
Your order includes:
- Two (2) RGBW Demon Eyes with sturdy JST connectors
- Two (2) constant current RGBW drivers, fully waterproof
- Brackets and hardware for easy mounting to a standard Mini H1 projector
Installation:
- Headlamps must be opened for installation (professional installation recommended)
- Brackets included for fitment in Mini H1 projector
- Demon eyes can be mounted with adhesive or custom brackets, for other projectors
- RGB or RGBW controller required for operation (not included)
All Diode Dynamics products are backed by a 3-year replacement warranty.
Professional installation is strongly recommended, as your factory Pontiac G8 headlights must be opened in order to replace the LED panels. Checkout our dealer locator tool:
Find a Diode Dynamics Dealer
Diode Dynamics RGBW™ LED Demon Eyes (Universal)
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Supporting Vendors
I remember these from years and years ago called "city lights". Kinda cool they're making a comeback after so long!
City lights are usually a 194-sized accent bulb used in factory applications
Demon eyes are a similar concept, except it's an LED added inside the projector to give it the "glowing bowl" effect
Thanks!
Nick C.
Supporting Vendors
Discussion Starter · #8 ·
so I have the spec D light assembly, plan on upgrading to Mini H1 projector, will this work with that setup?
The mounts for the RGBW Demon were designed specifically for the Mini H1 style projector. That would be the ideal setup for our RGBW Demon eye to be installed in.
Thanks!
Nick C.
1 - 20 of 60 Posts
