1 - 13 of 13 Posts
Hey all, new G8 GT owner and new V8 owner as well. Have had the car for 2 months now. (LOVE IT!) Bought from a local dealership, all stock as far as I can tell but does have a Roto Fab intake, after doing some research. Just recently installed Solo Cat-back Exhaust.
Eats gas like crazy. Well, not that bad but enough to notice. Yes, I know V8s are gas guzzlers for the most part. Idles fine and just changed the spark plugs and wires. Looking at performance upgrades and don't wanna waste money on things I possible have or don't need. A buddy of mine thats familiar with LS motors recommended taking it to a Dyno shop.
Thanks!
Next time you drive it, start it in engineering mode and you can see when 4 or 8 cylinders are active. While starting it, be holding down the left wheel switch on the steering wheel. A new menu will pop up and scroll to afm and drive it with that up. You'll know if it already has dod delete or if it's turned off by a handheld tuner.
CCG8 Member
Check the valley cover under the intake, if it's smooth, you have a DOD Delete/cam swap. If it looks like a brain, the DOD hardware is still in the car.
Borrowed the pic from another thread here... DOD is on the left, the bottom is towards the back of the motor.
it would probably be easiest to check for the plug at the back next to where the oil pressure sender screws in. If it's there like in the picture you have your answer.
You can disable DOD in the tune also but it doesn't remove the sometimes troublesome hardware.
Your gas mileage issue is probably due to that new right foot mod you just got... you know... that 6L V8 under that foot :)
Looking at the valley cover is the easiest tell tell sign that the DOD was physically removed. Just because the AFM doesn't engage doesn't mean it's not there. From what I have read, just turning off DOD doesn't completely remove the hazard of a stuck lifter, or wear issue causing internal damage.
Enjoy the car!! I'm in the market right now, and am getting nervous about timing. Lease is up in October, but can't afford 2 car payments (will be taking out a loan for the G8) for more than a couple months so I have to hope and pray that I find the car I want within a 2 month time period. I'm willing to drive 500 miles from NC so if anybody is thinking of selling.... :)
This.
Are you saying look for a cap like the red one that is on the smooth valley cover in the picture? I have had my car for about 6 weeks and have not felt or heard anything that would make me think I have DOD. The previous owner had installed a complete Kooks exhaust (except stock mufflers) and I'm hoping maybe they did a complete removal of DOD. When I checked the engineering mode it did say DOD was on though. Could the computer still read that DOD was on even if the internals were removed and replaced with non DOD lifters?
Mine still says dod is active in engineering mode, has been removed and tuned for 4-5yrs now. There's an electrical connector(I think 3 or 4 pin) in between firewall and engine block/cyl head for dod that should be disconnected if it's disabled. You can check that
CCG8 Member
The DOD cover is on the left, if you have that black electrical connect and unsmooth panel, the DOD hardware is still in the motor.
Engineering mode will show all active, as in all 8 cylinders are firing, under normal behavior. If it doesn't switch all during normal driving there then it's at least disabled in the tune.
What do you mean exactly?
If you've got Solo axle-backs just go for a drive on the highway and set the cruise. At any point while on a flat or slightly downhill you should hear the exhaust note change from a mid-bass tone to a really deep one. Trust me it's noticeable. especially if the windows are up. Sounds like a damn semi.
That or engineering mode like the others have said.
1 - 13 of 13 Posts
