Yes...I was looking at that one as well. Was also wondering if anyone had good luck with it.I've been considering this upgrade as well due to all the feedback I've seen about the crappy stock tensioner. I have no experience with this one but it looks like a quality unit at Marylandspeed.com http://marylandspeed.com/comp-cams-...-ls3-ls6-ls7-passenger-cars-54021-p-4827.html
Looks like a good product. How is the tension applied? Also, need a recommendation on a compatible belt.I used this one and works awesome!!!! I would never go back to a spring loaded tensioner... this one is actually cheaper and from a great company also....
http://store.katechengines.com/billet-belt-tensioner-p2.aspx
Looks like you put a ratchet in the top hole and put tension on it and then tighten down the jam bolt.Looks like a good product. How is the tension applied? Also, need a recommendation on a compatible belt.
