1 - 8 of 8 Posts
These are powder coated gloss black
19" cts-v sedan wheels
one has a small scratch on the lip i have touched up that isnt very noticeable ( see pics below )
Tires are new firehawk indy500 255/40/19 and 285/35/19 , less then a few hundred miles on the tires
Price is $1800
Im located in Central Connecticut
text me at 860-250-471 five for quickest response
2009 Pontiac G8 aka Karma
Glwts and kudos to the tire installer for mounting those tires correctly! I rarely see that these days(the yellow dot is lined up with the valve stem).
Reactions: maxspeed96ct
Yes, the minimal amount of weight is required that way. Just like our studs were marked to show it was set for minimal brake rotor runout
It’s been a while. Looking closely at the wheel studs after the wheel is off. The tip of one wheel studs is painted black
Here is one. End of the stud painted and a mark beside the stud. That way if it’s taken apart,it can go back together properly.
182691
Reactions: Northern_Holden
2009 Pontiac G8, Loudmouth Axleback, K&N
Still avail?? Where in CT are you located? I'm from NY area, right outside Greenwich
1 - 8 of 8 Posts
