frequency of rear speakers?
1170 Views 4 Replies 3 Participants Last post by  dal20402
i was wondering if anyone knew if the sound to the rear speakers on the rear deck were full range or just low frequencies for the factory subs. i want to take the speaker wires off the existing speakers and run them to the high side of an amp to run components. is this possible? thanks in advance
1 - 5 of 5 Posts
They are just low frequency subs.
The speakers themselves are only subs, but the signals feeding the rear amp are full-range and speaker-level (they share channels with the rear door speakers). The stock rear amp has a built-in crossover. You can use the input signals for the rear amp to provide a full-range, speaker-level signal to an aftermarket amp.
cool beans awesome, thanks for the input and the amp is located near the battery right?
Correct. You can find wiring diagrams in other threads in the Stereo/Electronics section that will allow you to decipher the harness to the amp.
1 - 5 of 5 Posts
