1 - 2 of 2 Posts
2009 Pontiac G8, Stryker Blue Metallic
Car was LS Swapped and rebuilt at 88k miles. Has a reconstructed PA title. Currently has 93k miles on it. Freshly inspected. $17,000 obo. Less than 5k miles on it since it was built. If you want a reliable daily driver, this is as fresh as its going to get in the used car market. Has been sitting on a lift in a conditioned building for the last 2 years. This would make an awesome daily driver, but I know the R-Title will be a hurdle for most. I have a build thread on here for the car, no expense was spared. I will get some more pictures this week.
New Body Parts Purchased for Rebuild
-GXP Wheels with Continental DWS06 Tires
-GXP Front Bumper (some paint peeling now)
-GXP Steering Wheel
-GXP Rear Valence
-OEM Hood
-OEM Radiator Support
-OEM Grilles
-OEM Headlights
Mechanical
-New aluminum 6.0 block, reused crank, rods, pistons
-new rings and bearings
-ati super damper
-new belt drive and all accessories (water pump, alt, a/c comp, ps pump)
-upgraded a/c compressor bracket
-ls9 cam
-gmpp blue ls6 springs
-new valve seals
-arp head bolts
-pat g engine/trans tune
-kooks long tubes - no cats
-corsa sport exhaust
-New engine & Trans Mounts
-rebuilt factory 6l80
-zl1 converter
-new radiator
-all new a/c, trans, fuel and power steering lines
-new coolant hoses
-rotofab cai
-holley valve covers
Suspension/Brakes
Front
-ppv struts
-tein springs
-new steering rack
-sueprpro front sway bar
-new front control arms and tie rods - mevotech
-new front hubs
-centric rotors
-6 piston yellow brembos front
-russel stainless braided brake lines
-Front cradles sandblasted and painted
Rear
-ZL1 Rear Trailing & Tow Arms
-Pedders Bushings In subframe and lower control arms.
-SS Aluminum Upper Control Arms
-Rear Cradle sandblasted and painted.
-Camaro 3.45 rear
-4 Piston Yellow Brembos with SS Rotors
Interior
-No real upgrades other than gxp steering wheel. Car needs a headliner, original was sagging and i ripped it off.
-Weathertech floor mats.
Car Wheel Tire Vehicle Grille
Motor vehicle Automotive tire Automotive exterior Automotive design Engineering
Blue Hood Motor vehicle Car Vehicle
Automotive lighting Automotive tire Automotive design Rim Automotive exterior
Automotive tire Motor vehicle Automotive design Wheel Automotive exterior
1 - 2 of 2 Posts
