1 - 12 of 12 Posts
Need some help. I had a difficult time removing the fuel line connector from the fuel pump and ended up damaging the quick connector. Fuel pump was cracked also and the reason for the fuel tank leak. Where can i get a quick connector or what size do i need. I will end up cutting off the damaged connector and attach a new connector to the nylon fuel hose. Any help would be appreciated. Thanks.
I recently destroyed mine too. They are not intuitive.
What he said^^^
I actually used a brass compression union that I got separately. The supplied plastic union is probably fine. Might take a little heat to soften the line.
Here is the completed job. New fuel pump, old one was cracked and leaking, new fuel pump gasket and new fuel tank lock ring. Nylon to nylon connector from advance auto and dorman fuel line repairkit from amazon. Thanks J Wikoff
Mine looks a lot like that now too.
1 - 12 of 12 Posts
