41 - 60 of 144 Posts
Thread sealant GM 12346004 / permatex 56521
Medium thread lock - Blue - gm12345382 / loctite 242
High temp thread lock - red - gm 12345493 / loctite 272
185277
185278
Another tip from experience. Two paint pens/crayons. One for when you torque the bolt, second for when you verified it. Two stripes, the bolt is done.
2009 GT, Black
Discussion Starter · #44 ·
Good tip..
Okay, real novice question..
When do I use the sealant, red and blue. Is there a document out there to tell me when to use each? I got access to the AllData web site. Maybe it is in there.. I'll look.
Any advice on the balancer and AC pulley?
The link in post 34 is color coded.
The gm dampener wobbles, some times excessively. It is often replaced with after market. I went with a ATI super damper. There are others such as powerbond - I have no experience with that brand.
AC wise, the pulley is not touched. You do have to pull the AC condenser bending the aluminum lines which is uncomfortable. If not present already, I recommend installing the revised double idler/bracket for the AC belt now while you have the front off.
2009 G8 GT WH
Not sure if you mentioned it but I recommend picking up a valve spring tool if you don't have one.
I went with the crank pulley from Summit as it was cheaper than the ATI balancer and appears to do the same thing, albeit as a 25% underdrive. No issues with it so far. Different sized belts are required but Summit supplies part numbers with the instructions for the belts. The crankbolt that comes with the BTR kit is an OEM bolt, not ARP, fyi. You technically "can" run the pulley in with the old bolt but just get an installer and play it safe. I'm not a fan of potentially damaging the crank threads. I didn't use a flexplate holding tool, just wedged a long prybar through the inspection port at the bottom of the bellhousing. Not ideal and kinda wonky but it works. Wish I had the holding tool to he honest lol.
Electric ratchet is fine for most bolts but some are a pain to access. A flex head long ish handled 3/8 ratchet works well in those cases. Various extensions both 3/8 and 1/2 drive are helpful.
2 of the biggest mistakes I made along the way were putting the flexplate on backwards (I didn't make sure it rotated after I installed it and had to pull the motor again to fix it). Not a huge deal but took another hour or so to correct.
Other mistake was forgetting to put the lifter tray bolts on. And finding the bolts on the workbench after installing and torqueing the heads. I ordered my BTR kit with oem headbolts so my brand new bolts needed to be replaced again. Ordered ARP bolts and corrected it the next day. Hooray Amazon 1 day shipping.
Get yourself a decent sized drain pan. Stuff leaks from everywhere and power steering and trans fluid leak quite a bit. You can get a large cement mixing tub from homedepot for around $10, perfect for sliding under the car and catching all the drips. Or just find a way to cap the lines. Don't forget to too off the transfluid as well (presuming you already will since you're doing the converter).
Also your long tubes "should" come with two O2 sensor harness extensions, mine only came with 1 harness so I ended up having to find one on my own.
Best of luck, take lots of breaks and don't make stupid mistakes like I did lol.
2009 GT, Black
Discussion Starter · #47 ·
Thanks for the comments.
This is my first time taking an engine apart so I plan on going slow.
A pan to catch miscellaneous fluids, I have found a hot water tank pan useful.
Organization, bolts in individual labeled zip locks as well as a list for checking off. At least it works for me.
2009 GT, Black
Discussion Starter · #49 ·
ok. And I grab one of those trays for all the head bolts, rocker arms, etc...
I like to take a cardboard box or large flat piece of cardboard, and make a crude drawing that matches the perspective I'm working on. Then just punch holes where the bolts go, and put them in there. It might take more than a few minutes to do, but certainly helps keep track of things IMO. Good luck and have fun, quite a list of parts you have!
-J
2009 GT, Black
Discussion Starter · #51 ·
Another decent idea.
Installing my third shock/strut now. 91 degrees in the garage. Came in to cool down a bit.. ..smiles..
I think I'll do the last one tomorrow morning before it gets to hot.
Since op is doing suspension, spec sheet.
Remember, for rubber bushings, tighten when the joint has weight on it.
2009 GT, Black
Discussion Starter · #53 ·
All shocks and struts are installed. Ball joints and other grommets look good.
Replaced front and rear stabilizers. They all looked like this one.
Font Wood Metal Monochrome Monochrome photography
Upgrading brakes next. Brake lines on their way. Awaiting the spacers to be made. 2-4 more weeks.
Maybe have the torque converter installed next if it gets here before the spacers.
Then the engine build.
Those are Moog sway bar links. Your previous owner used good parts it appears
Indeed. Those are Moog stabilizer bar end-links albeit prefer the previous ball joint rubber boots design as they seem to be more durable.
Yes it’s a reuseable bolt with just a torque number. No added angles
2009 GT, Black
Discussion Starter · #59 ·
I was just reviewing the DOD and Timing kit I received from BTR. Looks like they sent me BTR bolts for each as I didn't know what to ask earlier.
Should I return these and get the ARP bolts instead? I am assuming the answer is yes based on previous posts.
Are they stock bolts in your kit? In some ways stock bolts have held for ten years without leaks.
Now if I was adding a blower, ARP head studs or bolts would be a must. Now cam bolts, not a high stress location like a connecting rod bolt. I would add blue loctite to the bolts. Is the IWIS chain part of the timing kit?
