I'm currently running a returnless fuel system with CTS-V twin pump module (dual 340LPH pumps), Vaporworx etc... Using the stock hard lines wasn't an option as they were too corroded. The previous owner had ran a -6AN line in a similar fashion but in a location more prone to be subject to road blast and debris damage. So, since I was redoing the plumbing and talking to a few experts that have run big horsepower/similar setups -8AN made the most sense for the minimal cost increase over -6AN. Also protects for e85 if/when I go down that route. For now it's a 93 pump gas car. If I ever need to go to a return setup, I have some extra -8AN line I can run along side what I already did easy enough.
As far as the interchiller and the likes.. I looked long and hard at them, but decided against it due to the environment the car lives in. Winters gets down to -20F at times and summers don't usually peak over 100F. The benefit of the chiller would be great if I was running at a dragstrip repeatedly, but I'm not doing that. This is a daily/WINTER driven street car.
The IAT's have been fine with the upgraded hex, hex pump, bigger hoses and increased fluid volume. It has made a significant difference over the previous setup. While the car is idling, the ZL1 lid is cool to the touch just in ambient 70F degree weather. It only gets cooler when driving and air is blowing through the HEX. It's quite impressive. The other factor was the windshield washer reservoir gets deleted with all the chiller setups I've seen, which isn't acceptable for my application. There are also times when I drive with the windows down and HVAC off, so that isn't very good for the chiller setup either (effectively turns it off). The A/C also turns off when doing WOT pulls, so the chiller is really only about recovery time which even with the stock ZL1 HEX that was in there before, never had any issues in the summer while doing spirited driving and it having to pull any timing.
#1 priority for this build was daily drivability, reliability. So a lot of decision were made based on that factor. It's not an all out race car, otherwise I would have taken a different approach to a lot of the areas.
I'm curious to see how the new engine performs on the dyno once a bit more WOT tuning has been done on it. The previous "stock LSA" setup was making 550whp with a compromised oiling system (bearings were going, oil pickup full of silicone), broken piston ringland, and leaking injector, so there should be some serious uplift with the parts that are now in it. Butt dyno says at least 20more HP. haha
