BTW how hard is it to work under that hood, everything seems really tight... Especially for headers and spark plugs I'm assuming you'll have to do headers from underneath...
We need to see one on an L76 to know for sure. The heads and intake manifold are suppose to be better then the LS6 heads/LS2 intake manifold that are on the LS2.
I installed the Solo high flow cats and got CEL codes P0420 and P0430.
The other mods n my car are Vararam and Solo Mach shorty cat back. There is no tune on the car yet.
I installed the Solo HFC last week and had the Vararam and cat back for the past 4 years.
Jeff at Solo Performance said...
I do not know the part number for the front and rear lower door seals. This is the rubber strip that seals the bottom of the door with the rocker panel.
Don't know what its actually called.
Is there a code scanner setup that will read SRS (airbag) codes. as well as all the rest of the diag codes on the G8.
Will the new HP tuners setup do that? I haven't tried yet because someone is borrowing my MPVI
I have an airbag fault and I need to scan it before I take it to a dealer -...
