I don't really know how to diagnose, but it sounds like it could be the limited slip differential.
sorry work computer always has caps lock onLOOKING AT THE REAR DIF IVE NOTM SEEN ANY ISSUES AND HAVE HAD THE OIL INSIDE OF IT REPLACED ALREADY TO TRY ADN SOLVE PROBLEM BUT THAT DIDNT DO ANYTHING, IT OCCURS WITH THE STABILITRAK ON OR OFF IT DOESNT MATTER, THE STUTTER OCCURS EVERYTIME WITHOUT FAIL COMING FROM A FULL STOP, THE ONLY TIME IT DOES HAPPEN IS UNDER VERY LIGHT THROTTLE LIKE 5% BUT OTHER THAN THAT IT HAPPENS EVERYTIME AND ONLY UNTIL YOU ARE GOING ABOUT 5MPH THEN IT CUTS OUT
Are you thinking maybe torque converter or shift solenoid?Try starting in 2nd gear, see if it repeats.
ill give this a shot leaving work today see if anything changesTry starting in 2nd gear, see if it repeats.
ITS NOT THROWING ANY ENGINE CODES OTHERT THANM THE OCCASION LEAN CODE, however the stutter has been occuring since before the lean codes started popping upWell, thinking something in transmission. Other debug would be to pick rear up and check posi works correctly. Lasty would be an engine miss, I suspect codes would be throw if engine.
tried to start in both second and third just to see if it changed and nothing changed as it still made the same stutter, in sport shift it still stutters aswell.Try starting in 2nd gear, see if it repeats.
