1 - 6 of 6 Posts
Just redid them on Friday after changing a couple tires. Key in on position and hold the lock and unlock buttons on the key fob til the car beeps at you. You have 2 minutes a wheel to get er done. Start at the drivers side front and let air out until she honks at you again and move to the pass. front and repeat then the pass. rear and last the drivers rear. Then refill them all with air. Unless you have a bad tpms sensor it takes 5 minutes.
I had to replace the TPMS sensors on a 2008 Nissan Xterra early this year. So I would expect our G8s to be needing them, also.
My baby needs new shoes so will put a set of sensors in as the dash reading throws an error after about 20 miles/20 minutes of driving. All signs point to batteris needing to be replaced.
Had my sensors replaced all worked except the passenger side front replaced it again no work has anyone ever have this happen
1 - 6 of 6 Posts
