Correct, here is the official description of the breather from GM.
The Camaro equipped with the 1LE option comes with a PCV oil separator kit with instructions. The kit is in the trunk pack and should be given to the customer during the delivery process.
The PCV oil separator kit has been designed for off road use where temperatures are above 32 degrees Fahrenheit. This part was not developed for winter driving conditions, so it will need to be removed and replaced by the production PCV, if operating in those conditions.
Some race track conditions can cause engine oil to be ingested into the air cleaner thru the fresh air tube that connects the port located within the right valve cover to the air cleaner. This oil separator kit will improve that condition.
