1 - 9 of 9 Posts
Okay so,
Weird thing happened to me twice now. My car (3.6l/5L40) while cruising down the highway at 110 (kmph) shifts into park for a couple seconds then the car resumes.
The physical shifter itself is in drive. I hadn’t touched it. Just the digital display reads out P (for park) and it kicks the cruise off. Then it downshifts trying to figure itself out then a split second later it’s back to normal (in D again on the display) minus the cruise function until the car has been restarted.
Has anyone else run into this issue? I’m assuming it’s either a trans selector switch or a bad ground. But if it’s a common issue and someone knows it may save me some time and money!
Thanks in advance!
Super Moderator
To be clear, the dash indicator says its in park but it does not actually shift to park?
I think you're on the right track with the gear indicator switch (what ever serves that purpose on the 5L40)
Exactly. It tries to downshift though usually resulting in a miss and coast until it comes back
QUOTE="383_Stroker, post: 3725930, member: 23377"]
That’s what I’m assuming it is. I don’t have time to look at it now though so it’ll be a winter project.
I wanted to swap to a 6L50 anyway so if this 5l40 explodes in the meantime it’ll be a good excuse lol
Well considering that these cars are 14-15 years old lots of annoying little gremlins are going to pop up.
Time to break out the volt meter or visit a shop that specializes in auto electric.
I had a great guy here in Niagara Falls but he recently retired.
Check to see if P0850 is stored in trans data, If so the trans shaft switch inside of trans at shift shaft will need replacing
Reactions: TobaRiles
You can also check the orange/black wire coming from trans sw at trans to ecm for short to ground at its haress/s, when that wire is grounded it tells ecm it is in park
1 - 9 of 9 Posts
