What I did was cut out the inside where the stock housing sat in where the two mounting screws are. So the new fogs housing which in longer would fit in the car
housing. Than I made four L brackets and drilled two hole in each bracket
. Than I set the new fog housing in there making sure it was set flush in the front of the car housing where the lens sits in so it looks stock. Than I took the two L-Brackets per fog light housing and put the short end of the L-Bracket and slid it on the mounting screws that are part of the new fog light housing, than the long end I marked where it lined up on the car housing and than I drilled two holes one on each side. Than I put two screws and nuts to secure the L-brackets to the car housing. What this does is extend your stock mounting to accept the new fog light. Now I installed the new housing and mounted it to the new brackets
I made and there's no movement and it looks stock. Best thing I did and cost was cheap and no more melting of housing.Bought them on Ebay
03-05 DODGE NEON HALO ANGEL EYES PROJECTOR DRIVING FOG LIGHTS + 6000K HID KIT
