Have a 2009 Pontiac gt hard top convertible we got the roof won’t seal they say the microswitch is bad but they don’t make them anymore the part has been discontinued anyone have any idea how to by pass or fix this
We have narrowed the issue down but the issue we are having now is the part is discontinued and we cannot find it anywhere the part we need is a actually micro sensor so trying to find one or how to fix it another way I cannot post a picture
Thinking the same thing. It appears the part numbers are... 10364428 Release Switch RIGHT and 15841460 Release Switch LEFT. If so, they are readily available on eBay. If not, disregard.
not sure if you guys all know or not but aerpro in australia has made a dash kit with the heat controls built in. its way cheaper then the other versions out there. i will be installing it today. if anyone wants i will put up more pics and let you know how this goes. they have a kit for single...
It's been a long process but I've finally got Pat Guerra (who I totally recommend) to put a tune in right so the ECU is getting accurate speed readings and the car seems to be functioning better. I also had Chris White tune the BCM for the manual swap a while ago. Hopefully you guys might be...
Ok, as title says cigarette lighter plugs both stopped working at the same time. I have replaced the front and rear cigarette lighter fuses AND the #14 auxiliary power fuse. None of this fixed the problem and I have searched everywhere for a solution. Both stopped working at the same time...
Hey fellas,
I searched the forums and watched some videos but I could not fine exactly what I am looking for. The carrier bearing on my G8 is causing the the driveshaft to kinda wiggle around and make a clunky noise. So it needs to be replaced but it seems like it is going to cost me a lot...
