1 - 2 of 2 Posts
So my right low beam isn't working but my high beam is. I change the fuses and the relay and still nothing. Haven't checked for volts anywhere
G8 owner's spotlight? Keep it simple, remove the bulb and see if the filament is broken. If so, replace the bulb. If not, check the fuse as the relay is the same for both low beam headlamps.
1 - 2 of 2 Posts
