1 - 9 of 9 Posts
Trying to break loose these F'ing bolts on the cat/exhaust. Not sure I either have the right size wrench or what, damn thing isn't moving!
Anyone know the bolt size off the top of their head? Or a tip/trick to loose the bolts on the cat?
THE1ONE
Either heat the screw up a bit or WD-40....
<><>Morgen<><>
I've found the PB Blaster spray works much better at freeing up frozen bolts. It has better penetrating abilities than WD-40.
Ed B.
Awesome stuff! :judge:
SHTNGET
PB Blaster is the greatest thing know to man, that stuff will melt a Styrofoam cup. lets see some WD-40 do that. Plus i was a GM Mechanic for 6 years and PB is the only thing our parts department stocked cause even they know WD is garbage
Yea, I've got a bunch of PB Blaster on the sensors, but they aren't budging. I'm having my mechanic friend take a peek at it. Already stripped one sensor nut :(
1 - 9 of 9 Posts
