I attempted to take the cheap route and do a DIY air intake, I successfully created one for under 40$, but I have a few issues. I incorporated the stock air sensor and kept the EGR hose hooked up and it seems to be fine but upon starting up the car, the traction control won't turn back on (not the end of the world, I like to drive with it off) the radiator fans run at a higher rpm than normal, and my dash says contact dealer.
Any help would be appreciated!
Update:
Put old intake back in and it's doing the same thing, so I'm fairly certain that it isn't that.. I noticed that the oil temperature gauge is pegged at low which has never happened so I'm assuming that that is messed up too. I'm thinking I accidentally unplugged something. Again, any help is appreciated!
Update:
