1 - 20 of 20 Posts
Hey Solo, what steps should I take to adjust the J Pipes?
Any Suggestions? Tips? Tricks?
Solo has an instruction thread in their vendor area, I believe.
Capital City G8
Very simple. You don't even need jacks or ramps. 9/16th deep socket is all you need. Crawl under the car. Each J pipe has a clamp near the end. Loosen the two bolts on each clamp and adjust in or out in 1/2 inch increments. Be sure to mark your starting point for reference. I found moving it in makes the pitch higher and moving out goes deeper, but in all honesty, it doesn't do a whole lot.
^^^ so when it's install time, should you leave the j-pipes how they are when they are shipped...or based on the mods a persons car has and you encounter some drone should you move the j-pipe clamp closer towards the front of the car or move the clamp back more towards the rear of the car to get rid of the drone? i'm a little confused on this also. thanks!
Just leave them stock. You will need to run with the car for awhile anyways to break in the new exhaust. I've found adjusting the J-pipes did very little, if anything. Not to mention they are a pain to adjust on the axlebacks. They are in a different place vs the catback and it was very difficult trying to get to them on the car. I had to remove the whole pipe as my breaker bar was too long and I couldn't get my socket wrench in there without hitting something. Much easier just taking off the whole J-pipe then adjusting (which required a pipe wrench to pull out the one side, couldn't move it by hand).
Save yourself the time, and just install them at factory position.
have you guys had any drone with putting the j's on from factory? i know solo says it is a drone free catback system, but i thought there could be drone depending on mods. if the j's don't really do any changes does that mean the system doesn't drone at all?
I left mine the way solo shipped them and I dont have drone on the highway. I thinks it sounds badass at 85-90.
Capital City G8
I have some drone/slightly unpleasant sound from 1200-1400 rpms which occurs in 6th gear from 42-52mph. It only occurs when the car is under load as in going up a slight incline when the car doesn't kick down to 5th gear. It's not horrible by any means. I spent 5-7 hours adjusting my J pipes in and out by as much as 1.5" It changed the pitch, but never got rid of the sound. To be completely honest, adjusting the J's doesn't do much. I ended up keeping mine at the stock location because it was the best overall. At highway speeds, it's extremely quite and no drone whatsoever. I think your jumping the gun on this. Sit back and enjoy the sweet exhaust note!
^ +1. I encounter the same resonance at those speeds. AFM is the only problematic area for me. Just too annoying at 74mph turning on andoff. In 8 though it sounds great
AFM has overall become a nuisance with the new exhaust I must say. The constant engage/disengage is the annoying part. Unfortunately adjusting the J's had no impact on AFM. I may just shut it off at some point.
Capital City G8
AFM with the full catback isn't nearly as bothersome as it is with the axlebacks. The sound didn't really bother me much, but I tuned it out anyway.
Agreed. Make sure you tighten your bolts to 60ft lbs torque too. I noticed going back to the stock position on my car this morning reduced some vibration I was experiencing with my J's pulled out 1". My suggestion is to keep it in the stock position and make sure all bolts are tightened to spec.
I've had a different experience.... My system droned like crazy for when I put it on. I adjusted the pipes all over the place with little change.I even spoke with Steve several times, but while taking a closer look my 2 j bends (I think its easier to adjust them off the car) I found they were different lengths and therefore when I made my adjustments the pipes were never the same lengths.
I ended up wrapping a string along the outside of the pipe to make sure they were adjusted to the same length. This made a HUGE difference but I still had that annoying drone/vibration below 1400rpm when under load. I since have moved them about 1.25" out from the factory solo setting and am loving the results. I have yet to turn back on AFM, but before it was absolutely unbearable... However since I installed the axle back my mpg has gone up even though AFm is off and I know I'm driving it harder just to listen to the exhaust haha. I think it sounds fantastic during spirited driving right around that 1800-200rpm mark.
Definitely easier to take the pipes off. I made sure to measure with a straight edge and position the pipes at the same distance from one another (9" from the pipe bend to the end of the adjustable pipe is the factory position).
I think you're the first I've heard with successful results moving the J-pipe. Glad it worked. I still need to put more miles in my stock position again since I've been running outside the stock parameters for awhile. Nothing really different but vibrations APPEAR less than before. The mind can play tricks on you when you first make changes (aka like a butt dyno, tough to trust).
up-down-charmed-strange
... I ended up wrapping a string along the outside of the pipe to make sure they were adjusted to the same length. ...
Yes, I did the same thing before installation (hadn't had any beer yet):wink2:, since equal lengths is a critical function. I measured from the weld to the end of the cap with a piece of wide non-stretchable material that hugged the contour. I'm still at the "default" position, but might try making them @ 1" to 1.5" longer sometime in the future. For now, I'm just lovin it!
Mine wound up a tad off after the install resulting in a slight buzz. measured and readjusted and buzz is gone. Still have to work on the AFM changeover.
Reset J's to 9' from bend. Total length on both J-pipes is 23.5"
I just got my Solo Mach Balanced system on and I thought that it was the combination with my Kooks headers that was causing the issues, but it sounds like everyone here is seeing the same things I am.
It sounds "nasty" in a good way, but the AFM change is really annoying me and I've resorted to driving in manual mode. I might have to get a AFM disabled tune from VMS.
I've put about 500 miles on it. Everything was new - how long should i expect to drive it before it gets enough carbon to mellow the sound a bit?
cvidt said it sounds great around 1800-2000rpm - try headers, HF cats and solo catback at 5K RPM. It put s smile on your face :) I've had to start idling around my general area where I live because people were stating to get ticked off. I usually hit it a little leaving our neighbourhood onto the main road, which is about 1/2 a mile from our house - the other day my wife said "you know I heard you leaving the neighbourhood - you better not get any tickets" I could only smile.
I think it sounds fantastic during spirited driving right around that 1800-2000 rpm mark.
Spirited driving is not possible below 2000 rpm:driving:
Vendor
Break-in can take up to 1000 miles. Carbon needs to build up inside the pipes. From that point, you can try adjusting the J-pipes in half inch increments. Make sure both sides are the same length.
G8/LSX n00b
If anyone needs a set of new stainless 2" J pipes, PM me!!
1 - 20 of 20 Posts
