1 - 20 of 46 Posts
That's right boys and girls, The Junkman has went and made paint correction so easy, a caveman could do it! In the following videos, I cover the entire process from start to finish. The first two videos are worth their weight in gold for the information alone. I don't even start working on the paint until the third video but the amount of information I cover in the first two videos is priceless. Do NOT skip through them!
If you have ever been apprehensive about using a machine to rid your paint of scratches and swirls, you will definitely not be worried after watching this video series. I break it down to a level where a 10 year old can watch these videos and start fixing paint. The supplies and equipment that I use are readily available in the USA and abroad (for the most part). If you have a serious desire to finally fix your paint and about 1 hour and 54 minutes, then this video series is totally for you. After you have watched this series, you will not believe how easy I have made this.
So sit back and get out some popcorn, kick up your feet and enjoy. The Junkman is about to burst onto your screen in a way that only the Junkman can! :thumbsup:
Here are your before and after shots, which won't make a lot of sense until you have watched the videos, especially when you see how the number "2" ended up in the paint!
BEFORE...
AFTER!
Part 1 - Hey boys and girls! Finally, a video series that takes the process of paint correction from the beginning to the end (from claying to waxing). Although I do not apply any wax at the end, I cover everything else in detail. This series is 1 hour and 54 minutes long so that should give you an idea as to how much detail I go into.
In this first video, I talk in detail about exactly what paint correction is. I also go into detail about the polishing technique you should use as well as the best product on the market that you should buy. I cover other topics too so just sit back and kick up your feet. This video is 15 minutes and 7 seconds long.​
Part 2 - In this video, I go into detail about exactly what I use to remove the paint damage within this video series. I name and visually show every piece of equipment as well as all of the products necessary to do paint correction. In some cases, I even offer up a location where you can find the products that I use. I talk about why I chose to use the products that I use as well as what I don't use. If you want a list of these items, WATCH THIS VIDEO.​
Part 3 - Okay, in this video I identify the damage that we are going to repair. I even go as far to create some damage just to ensure that my paint will be more jacked up than your paint. I then go into detail about claying, and what it does for your finish. Last of all, I show how to assemble the PC-7424XP so that we can start the polishing process. The video following this video will be in high definition so that you can clearly see the damage and the effectiveness of my repair.​
Part 4 - Because I wanted the viewers of this video to be able to see the results of the work that I did in high detail, I uploaded this video in high definition. That took 12 hours!
In this video, I actually go into the proper technique for polishing with the PC-7424XP, showing me using the machine properly. I show the polishes that I use, the pads that each polish is used on, how to work the polisher and how much polish should be used. I also talk about the importance of not using too much polish and clogging up the pores in the pads, which makes the whole process worthless. I go into the discussion of how long to work a polish and when to stop (after a polish flashes). I show which order the polishes are used and explain why you use them in that order.
One thing that I stress in this video is the importance of a solid technique. I talk about and show the technique that I use, as well as how to ensure that you are developing a solid technique. As I say often in this video series, "Technique trumps product 365, 24/7. No matter who's polishes you decide to use, none of them will work worth a darn if your technique sucks. Technique rules!​
Discussion Starter #2 (Edited)
Conclusion - I recap my process and allow you into my mindset concerning paint correction and caring for your paint.​
The Junkman :patriot:
Thank you for doing this! I will watch it when I am ready to do my GT for the first time.
I never have understood how the Grit Guards worked until these videos.
I've always used Meguiar's and Mother's stuff in the past but this has convinced me to give Adam's a try!
I have used Meguiar's stuff also and there is nothing wrong with it. Very good products in their professional line. However, the Adam's stuff is so simple to use and the customer support is unheard of. Lastly, you can call the owner up and talk to him personally. If you ever need to, look me up. I'll give you his personal cell phone number. :thumbsup:
It is amazing what a good detail with a PC can do. I use Menzerna products and got this result:
BEFORE:
AFTER:
And for those of you who wanted a G8:
BEFORE (swirls around the flash)
AFTER:
Brewtus
Saving this thread!! I can't wait to do this to my G8! My dealer must've neglected the hell outta my paint before I picked up this car. Also, right before I took it for a test drive, the owner of the dealership and my salesman took it through their machine wash with me inside it! I wanted to kick the guy outta the car! Very good info in these videos! I can't wait to pick up my tools and polishes!
Discussion Starter #16
Contact me if you have any questions on the process. I posted another video series that goes over just the polishing part. Check that out too. :)
I Void Warranties
Just watched all the videos. Nice job!!! Thanks for the help. It will definitely come in handy in a few weeks.
Thanx again AJ!
1 - 20 of 46 Posts
About this Discussion
18 Participants
Junkman2008
Full Forum Listing
