1 - 8 of 8 Posts
I heard a friend talking about HPTuners having the ability to "compare" maps. I should be getting my HPT any day now. Could I just download the Superchips tune I have in the car now to HPT? Then flash the car back to stock with the Superchips Cortex. I would assume I could then disable the cat efficiency code and flash the car, using HPT, with the map from the Cortex. If that works, I could go get the car tuned properly in a week or so. I cant stand the CEL. Since its been on, I cant remote start my car. Very irritating. Is this normal?
Yes, I did this when I first switched to HP Tuners.
Sweet!
Discussion Starter · #4 ·
Woohoo.. it arrived today. I had to make an ISO file because my ultrabook doesn't have an optical drive, but its installed! Now I need to go get the tune off the car & put it back to stock. Then reflash using the HPT with the Cortex's tune.
I was able to load the Cortex tune into HPT. I then flashed the car back to stock with the Cortex. I then went into HPT and disabled 0420 & 0430 to get rid of the CEL from the header install. Now I just trying to get a date set with MASE to get the car tuned. Hopefully I will be able to drive to Jacksonville the fist part of May to get tuned.
Its Good To Be Tha King
fyi You can clear the codes with the cortex. They come back after a few hundred, just clear them again. The process is much quicker than tuning.
Set to 3 on the DTC and uncheck all sensor 2 o2 codea and you ahould be fine. You may have another code pop up thats like a P1xxx for cat low efficiency.
hi guys
ed: Hijacked my screen name sorry..
1 - 8 of 8 Posts
