1 - 5 of 5 Posts
Hey y’all, I’ve been needing to test some things out on some clusters I have as I need to figure out which one is problematic and what exactly the problem is. I was wondering if anybody knew which of the pins was the ground? I would test the wires in my car but I don’t have it at the moment so some information on which pin is ground or the whole pin diagram would be appreciated. Thanks
184473
184474
184475
184476
184478
2009 GT Instrument Panel Cluster (IPC)
Pin Wire Color Circuit No. Function
1 0.5 OG/WH 1840 Battery Positive Voltage
2 0.3 GY 728 Security Indicator Control
3 -- -- Not Used
4 0.3 BK/PK 353 I/P Module Suppression Indicator Control
5 -- -- Low Washer Fluid Indicator Signal
6 0.3 BN 7312 Left Steering Wheel Scroll 1
7 0.3 GY/BU 7367 Right Steering Wheel Scroll 2
8 0.3 BN/GN 7364 Right Steering Wheel Scroll 1
9 0.5 BK 850 Ground
10 0.3 PK 3 Ignition 1 Voltage
11 0.3 BN/WH 419 MIL Control
12 0.3 OG/BK 5201 Steering Wheel Controls Signal
13 0.3 BN/WH 33 Brake Warning Indicator Control
14 -- -- Not Used
15 0.35 D-GN 9203 Low Speed GMLAN Serial Data
16 0.3 BK/BN 723 I/P Module Disable Switch - Signal
17 0.3 L-BU 7313 Left Steering Wheel Scroll 2
18 0.3 BN/WH 897 Steering Wheel Controls Low Reference
Discussion Starter · #4 ·
3 -- -- Not Used
9 0.5 BK 850 Ground
14 -- -- Not Used
Thanks so much, really appreciate the help. Pretty sure you responded to my other thread too so thanks a lot again. I’ll be testing my clusters out soon so wish me luck!
You're welcome and best of fortune.
1 - 5 of 5 Posts
