So the car has now been started five times and let idle and it appears my oil pressure problem has been solved but I’d still love to know what happen. The inside of the oil pump looks absolutely fantastic no gouges or scrapes the plunger seems to move freely and is not scored or chewed up in anyway. The only thing I can think of is that pick up tube O-ring as you can see in the pictures has a large gap almost all the way around. The new O-ring barely fits in the hole and was a nightmare to get back together. My only problem now is I have a knock sensor code and a 5 V reference code which I believe is for the knock sensor I’m hoping that maybe I pulled the wire when I pulled the oil pan down or maybe unplugged it. Also now I have a small oil drip under the car and I know for a fact I put very good gray RTV in the corners of the timing cover and the whole bottom of the timing cover where it meets the oil pan just to make sure. I’m keeping my fingers crossed but so far the lowest the oil pressure has gone has been about 36 and that’s at full operating temperature.
