1 - 12 of 12 Posts
Did a seach and didn't find any posts regarding this. I just bought a GT and it has a JET stage 2 module installed. Seems to work well, although I don't have anything to compare it too. I'm not crazy about the fans always being on and stating on after key off for a few minutes.
Looks like a pretty simple installation, just goes inline with the PCM and it's harness.
Would I be better off to remove it and install a cortex tune? Or does anyone know of a tuner in southeast Ohio?
Super Moderator
Isnt the JET stuff along the same lines as the fake ones on eBay? A cortex would be night and day better I would think.
My thought too. Can you post a picture of what it looks like? Ebay sells a wide array of clip in place "Chips" that claim 50+ hp and 35 mpg. Scammers Delight. I wish ebay would shut that crap down.
The Cortex would be a great replacement for what you have now. They can be had pretty easily on the board pre-owned for ~$250.
^ That's it! As for what it is doing exactly to the car? Probably not much.
Other than keeping the fan on, I don't know. Going to pull it off Monday and reflash the ECM to stock at work. So when I get the cortex it has a good base program to use.
It's just intercepting a few signals that the ECU uses and changes it(ie.. tricks the ecu into seeing a lower intake/water temp). It's cheap crap
Id pull that thing and ebay it. Then purchase a Cortex if you want a simple programmer.
Discussion Starter #12
Pulled it off, but it appears the previous owner also programmed the ECM too, hence my other thread. Fans come on at 195 and stay running after key off and DOD is disabled.
1 - 12 of 12 Posts
