1 - 4 of 4 Posts
In the pictures you will see below these are the things needed to remove to get out of your way to remove the key for again this is a temporary solution. There's a little pain in back of the ignition switch looks like needle almost all you have to do is pull that out and turn the key back all the way and you'll be able to remove the key. To help out I Circle it that little pin that is in the circle is what you need to pull towards the pedals and then turn the key
After all said and done ended up being a fuse at the kick panel. F16 I believe. Wasn't blown all the way so I believe that's why sometimes the key would come out and sometimes not. Hope this helps anyone with similar issue.
Good information and will bear this in mind if the problem arises in the future.
1 - 4 of 4 Posts
