1 - 8 of 8 Posts
So I've really started to notice the dreaded lifter ticking.:sneaky: I'm going to have to save up for a DOD delete package. How long before something "catastrophic" happens?
Good luck, just had mine repaired last month under warranty. Lifter tick is not the same as lifter failure, hope you can identify which one you have.
Depending on how bad it is, it can beat up the cam. I'd bring it in for warranty work. Mine had the tick at 20k miles and they were replaced by GM. At 62k miles now and not a single tick since then. I'm doing a cam swap next month so it's all coming out anyways... Thank God.
Cant bring it in for warranty work. I have an 2008 with 97000 on her. My gas mileage has really been suffering lately so I'm not sure if its lifter tick or failure. I've lost about 3 mpg in the past 2 months. Or it could be that I just need a 100,000 mile tune up. Cam package will be doable in about 2 months. Just hope it makes it that long.
Powertrain is 5 year, 100k miles. Depending when purchased off the lot for original titling, you might still be covered.
Well I'm the second owner so I've got no clue. Is there a way to find out using the VIN?
Call GM customer service or your local GM service department and ask if you have any remaining warranty. They should be able to help.
I'll give them a call tomorrow. Hopefully, its nothing serious and/or still under warranty.
1 - 8 of 8 Posts
