At least for me to get an understanding (of what is an isn't happening), you best re-post with more information. Such as, are all 4 gauge readings inop ? Are all the background lights within the cluster inop ? Are all other background lights (on steering wheel, upper an lower console, DIC, external lights control panel, an overhead dome light panel, etc) working correctly or not ? Will the the DIC display its successful system tests at full ignition turn on ? Does that MIL light extinguish after engine start ? As well as all other things you know to be incorrect.
An you should get this problem moved over to the *Stereo/Electronics* section.
