Any leads on a low mileage or otherwise decent condition differential for a '08-'09 G8
GXP 6-speed manual I would greatly appreciate it. Trying to get my daily driver back on the road🙏🏽🙏🏽🙏🏽
Hi GreenA few years ago I was trying to sell my GXP diff, but with the ever increasing rarity of GXP parts I've decided to keep all of my parts. I have the Camaro 1LE 3.91 installed now and I would recommend the diff. If possible, also upgrade the axles to help keep the wheel hop to a minimum.
Here's what I have installed. I drive pretty conservatively, but no wheel hop.Hi Green
Could you elaborate on the axle upgrade? Which ones would be a direct swap and eliminate WH? I have a Manual GXP and have never spun tires intentionally - because of the tremendous WH issue. It WILL break something!
TIA
Thank you all for your feedback. It has been extremely helpful. More than likely I am going to go the 1LE swap route and I'm going to rebuild my old one and keep it available just in case. The rear axles and wheel-hop is also something I will look further into as it has already been an issue. I appreciate you all.
I've noticed tires have a big impact on Wheel hopHi Green
TIA
I've noticed tire wear and pattern have a big impact on wheelhop in My all-stock G8 GXP.Hi Green
TIA
I can vouch that these bolt right into a manual transmission GXP. However, not sure of the current availability of them thru GM. Years ago when I needed, a second one, they were on back order.Upgrade to a Camaro 1LE 3.91 diff, you won't regret it.
