1 - 4 of 4 Posts
Looking for Infinity Door Speaker Replacement help
I need to replace the factory door speakers. Can no longer wait One in the rear door rattles. I want to avoid to change the sound balance (i.e. center speaker). Therefore, I would like to go with 2 Ohms.
I found the following Inifnitys:
F -FRONT doors 6030Cs
R -REAR doors 6032si
It seems a straight forward installation according to this:
http://www.g8board.com/forums/showthread.php?t=28009
However, I'm not sure how to deal with the fronts. The set comes with 2 crossovers. Can I just install the two main speaker and keep the crossovers and tweeters in the box? The thread above is talking about a capacitor...
Discussion Starter #2
Just realized, there is also a Kappa line:
Front: 60.9CS
Rear: 62.9I
Kappa are 2 Ohm as well. But seem to have slightly higher sensitivity (95dB) than the Reference (93 dB).
Anyone around here who installed either?
Thanks for the links. Great info.
I still have a question regarding the crossover in the front doors. While the 60.9CS comes with a crossover I thought I just use the G8 stock crossover (wherever it is) and just use the main speaker in the front doors. Is there any reason this would not work?
1 - 4 of 4 Posts
About this Discussion
2 Participants
sander
Full Forum Listing
