1 - 4 of 4 Posts
G
LSX “StreetBeast-DOD” Camshaft KitOur mid-range dual-purpose DOD-AFM spec camshaft kit.
Custom “StreetBeast” Series Hydraulic Roller Camshaft
PAC Racing 1218 Beehive Valve Springs - Max Lift .600”
Steel Shelled Viton Valve Stem Seals
FTI Pro-Series, One Piece Hardened Pushrods
$799 Shipped!
LSX “StreetSweeper-DOD” Camshaft KitOur most popular dual purpose grinds. Big torque and power maker.
FTI Seven Degree Chromemoly Retainers
FTI Hardened Seven Degree Valve Locks
$950
Shipped!
LSX “StreetSweeper-DOD” Deluxe Camshaft KitOur most popular dual purpose grinds. Big torque and power maker.
Yella-Terra L92 Aluminum Roller Rockers
$1350 complete & Shipped!
All the above cams are designed to work with the DOD/AFM for your car so you can get the best of both worlds. Orders will be placed as received once we are out of stock it could take a couple weeks for you to receive yours as they will need to be ground then shipped.
*Prices shipped are to the lower 48 states
Cams are always a great way to go to increase power, as the stock cams in our motors are really pretty mild. But they are also designed more for efficiency and emissions than for peak power. The drawback to a cam swap is that they are usually more $$ and labor intensive than basic bolt-on modifications.
Flowtech Induction is an excellent shop than can custom grind you a cam to fit any other mods you might have. You just tell them if you are looking for big torque increases, HP, or whatever you want and they design a cam to meet your needs. They will probably be a little more $ than a regular "off the shelf" cam, but it is tailored to your specific needs.
What are the specs on these cams. Im looking to get a cam soon but I want something very mild that will sound stock.
1 - 4 of 4 Posts
