Almost ALL LS engine failures are traced to leaks and low oil pressure. Start with the big one, DOD lifters. The only real problem with them is the limited internal travel limiting them to .500” valve lift. The pins getting jammed and the lifter collapsing is caused by low oil pressure. That’s it. It’s not metal fatigue, it’s not advanced wear. It’s all from internal oil pressure leaks. The pick up truck crowd sees it better because they have oil pressure gauges.
There are plenty You tube vids that show the before and after of replacing the pick up Oring, porting the oil pump and adding a couple little washers to raise the base pressure. If you find your hot idle oil pressure dropping to 20 psi or less. You are in Big Friggin Danger. Turn you AFM off if you can. GM made a big mistake on our AFM system. They gave us a good high volume oil pump. But made the oil pressure so low to protect the LVOM solenoids.
Now add in the pick up O ring leak and oil pressure drops too low. This is the #1 cause of DOD failures. Easy to do during a cam swap, but every LS motor needs this. And the cure is simple. Again it’s GM fault. The pick up tube has only one bolt, but the oil pump can take 2 bolts. Adding a bracket so the pick up tube is held on both sides will extend the life of the O ring. With it held with one bolt a fresh O ring seals but as it gets old and flattened
it leaks. You can buy a bracket for the other side of the pump and a 2 bolt bracket. Either work and can be bought for $15 to $30 plus an O ring. Add 20 to 30 cents for the washers to shim the oil pressure spring and that it for the parts. Gaskets a balancer bolt and rent or buy a puller. This will fix the biggest weakness any LS engine has. Then there is the pump itself.
I have seen new pumps that now have a sealing ring between the pump and the block to prevent leaks. The bar bell or dog bone in the oil gallery at the back of the block. Also a good idea if you have the trans out or engine.
All are good if you have taken care of the main fault.
