Nice, 362 at the wheels would be about 400 at crank +/- 10hp. Did you keep the same valve-train/spring set up? And did you do it yourself and how much it'd cost you?
I wonder now what I'd get with BTR stage 3 with similar setup (with valve springs and johnson lifters.)
I am going to change out the hose. I see there is a plastic ring at the end near front of car, inside hose end . Where do I get another one of these, and is it necessary.?
Also, any confirmed part number for AMAZON hose order ? So much mis - info and real info out there re the correct hose. 2009 gt.
I recently completed my dod delete, cam swap , and also did full rebuild due to mileage on my 09 g8. Has a base tune to get motor to do some heat soaks. Problem is now that I put an exhaust on it has a slight tick at idle sounds like it’s from the passenger side but I used a stethoscope to...
My M6 GXP is starting to make the dreaded "ticking" lifter noise at about 77k miles but I am thinking before I head to the shop I should run some seafoam (and maybe lucas oil treatment) through the system.
My plan of attack is as follows
1 Gas tank is almost empty so fill up with at least 93...
I have a GXP, totally stock. I want to add an oil pressure gauge. The gauge I am looking at says it plugs into the OBD port under the dash -- so no need to get under the car and add on an oil press sending unit to the engine. But do these cars give oil pressure through the OBD port? Is there an...
