1 - 11 of 11 Posts
After the cam install I now have trans slipping in 1st & 2nd gears. Third seems to hold. It drives fine under 3k rpm, if you get on it above 4-4500 it slips, it seems to grip & then slip but once it hits 5-5500 it will slip up to the shift point. Just had the fluid changed & checked it tonight (was fine), reloaded the tranny tune but no help. The tranny was fine before the cam install & has about 300 miles on it since the cam install, 60,000 on the tranny. Any ideas what this could be? Wifes gonna be bent if I have to rebuild the tranny now!
Discussion Starter #2
So after talking with some people in the know, I've come to the conclusion that I may need more fluid. Anyone else have to add more than full to get the tranny to hold 1st & 2nd? I was told that sometimes an addition 2-1/2 quarts from full is needed.? I tried 1 extra quart but didn't do the trick, put another quote in tonight but I can't try it out for a couple of days becuase of the snow storm we're getting today(Iowa). I think that I'm reaching for a simple fix but I hope they're right!
MUSCLE Biotch!
Was all of the tranny fluid drained from the lines also? That also accounts for volume when adding fluid, not just what sits in the pan.
I found on my other car that the tranny was slipping on 1 to 2nd shift and checked my fluid and it was low. Idiots at Jiffy Lube didin't fill it all the way. When I added more, the issue was gone.
Anyone know how much fluid should be added when dropping the pan & changing the filter?
No kidding! I've had nothing but bad luck here lately. I'm about to the point to just drop a new trans in and trade it!
Well I'm about done with my cam swap, I know I'm gonna have to replace the oil pan gasket but I'll get to that once I put a couple hundred miles on it. Its not leaking bad, and I don't feel like changing the oil again. I would recommend dropping the trans pan and get a new filter and flush the fluid. Your post have gotten me paranoid!
I just had that done & the slipping got worse! I can only hope that I was a little low before & even more so now. I added my 2nd quart over full today but will have to wait a couple of days since we're having a snow storm last night & today. I went from burning up tires to the tranny in 200 miles. If I didn't have bad luck I wouldn't have any at all. What's a guy to do, kinda stuck now!
Cars are my hobby...
How are you checking fluid level?
Car in the air running, trans @ 32-34 degrees C. Take out the bolt in the bottom of the pan, if oil comes out assumed full.
My old oil was not burnt & no solids floating around. My trans was fine before the cam install. I've been told that some G8's take up to 2 quarts over full otherwise it will slip. Somebody from Century today & they said it's probably in the tune. He also stated that some G8's benefit from upgrading to a camaro pan & filter, I guess under heavy acceleration the G8's filter can't pickup the fluid. I ordered the pan, gasket & filter from Pace today. Hopefully get rid of this snow in the next couple of days & get the new trans stuff on by Friday. This has turned into one after the next!
1 - 11 of 11 Posts
